Thread: rusted noise
Old 1st October 2017, 11:54 AM
I'm not aware of anyone doing an oil change (correctly) on a D3 and making the gearbox any worse.
I personally did the 4.2 Tdi that Oli is currently selling at around 100k and it went from pretty good anyway to feeling brand new with a simple oil and filter change, clean of pan etc.
I really can't emphasis enough times not to your use Audi however for the job, as they'll give 'the simple job' to the freshest student in the place who won't give too hoots whether the oil level is spot on, or likely go to the efforts of cleaning the pan.
From distant memory, I think the W12 and 4.2 Tdi use different gearbox oil due to the torque, but the rest are cheaper stuff.....
The hoot will be a semi-blocked filter that is starving the box of oil creating a high pitched sucking sound as its getting air, not oil.
I would imagine the issue can only get worse rather than better if left.
If you speak to a decent transmission specialist, and discuss the symptoms hopefully they will give you some sensible feedback and suggest the best course of action.
Audi won't do this. They have no idea whatsoever about gearboxes. Its a part number. If its bust. They change the whole part...!
Did I mention, don't take it to Audi ?
And don't take it to joe bloggs regular car garage either. This isn't a Toyota.
Take it to a *transmission specialist* who fixes these things day in, day out.
