Originally Posted by IT
So, the final, and least likely culprit is the wiring. Its a perfectly intact, unmolested beautifully looking loom, so it made no sense - but - I did find that the VW Tourag had an Technical Service Bulletin out regarding a similar issue that suggested that the connector on the Throttle body, having only 6 wires, was prone to a bit of movement and could over time cause problems.
So having replaced the connector (and by the sound of it a length of loom leading to it) was there any detailed examination to see what had failed?
Things that spring to my (relatively inexperienced) mind would be:
- Contamination/corrosion in the connector(s) that mate to the throttle body.
- Wear/looseness in these connectors.
- Poor contact between the cable core and the connector due to manufacturing problems or wear.
- Connector insecure in the plug body.
- Failure in a cable core.
I'm sure there are other things to look for as well.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
