Originally Posted by HPsauce
So having replaced the connector (and by the sound of it a length of loom leading to it) was there any detailed examination to see what had failed?
Things that spring to my (relatively inexperienced) mind would be:
- Contamination/corrosion in the connector(s) that mate to the throttle body.
- Wear/looseness in these connectors.
- Poor contact between the cable core and the connector due to manufacturing problems or wear.
- Connector insecure in the plug body.
- Failure in a cable core.
I'm sure there are other things to look for as well.
With hindisight, perhaps I should have asked for the old bits they removed, but to be honest its been quite a chew on to manage the operation long distance as it is with everything else going on.
My strong suspicion is that the cable core had a number of frayed strands where it 90 degree bends towards the throttle body.
The connectors and pins had been thoroughly inspected and cleaned several times....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
