Old 30th October 2017, 08:23 PM
327G is the non-sport bar at 26.8mm. 327H is for the sport bar at 29mm.
Interestingly, the Lemforder equivalent of H is listed as 27mm so presumably the aftermarket are specifying the diameter of the loose bush as 2mm smaller than the bar it fits.
Also, the Meyle bush is softer than the Febi so not the preferred choice in this instance. Not sure about the Lemforder.
