Old 3rd December 2017, 05:35 PM
I’ve spoken at length to the head technician at Mackies (the Glasgow ZF gearbox specialists) on the 3 occasions that I’ve had the fluid in my box changed (and flushed with warm oil through the specialist ‘pumpy-squirty’ machine). To summarise, he regards the gearbox as a unit of metal parts filled with oil which is circulated through a filter to remove particles caused by wear - not too dissimilar to an engine - so why would you not change the oil? My car has now done just under 179K miles and (touch wood) the box (which has had at least 4 fluid changes to my knowledge) is still going fine. Mackies charge a little over £100 (IIRC) for a ‘gearbox service’ and a replacement gearbox is around £3K. If it’s done properly, changing the fluid can’t do any harm, so why wouldn’t you if there’s a probability of it extending the life of your gearbox?
