Old 3rd December 2017, 09:02 PM
Originally Posted by Mechcanico Lee View Post
Thanks for taking it apart so we can see how it works ....always good to have an understanding how things work
Thanks matey, will try and go a bit further in tomorrow but was pushed for time. Never seen this waterpump/magnet arrangement so would be interested to see further in. The E28 BMW I had in the 1990s had heat in the cabin all the time the valve block was shocking quality in comparison but was made 30 years ago I suppose.
Mine has done 260,000 miles so can't grumble. The pump runs from idle until 2000 rpm according to Self Study Guide, I can see why, without it that is when the heat output becomes feeble. It also runs with residual heat function and I concur this stopped giving heat for more than 30 seconds.
The pump will also pull enough warm water on a winter's morningto pre heat the cabin, but only if the Aux heater is turned on manually via holding ON/OFF on climate panel to make it come on without ignition and selecting HI + HI on temps. If making the AUX heater come on via the timer menu (activated via VCDS) then this pump does not come on and no heat is pulled up which is a shame. I have the extra pump V55? to fit to the Webasto but will probably never get around to getting the other parts and fitting it.
