Old 5th December 2017, 07:17 AM
Now that I've had my porridge and a cuppa the grey cells have started to work a little.
The ON/OFF button in the climate control must have a pair of contacts that are closed when the button is pressed. Is there a way to locate these contacts and connect a set of relay contacts across them? I'm thinking that if this is possible a remote could be added to switch the Webasto on from indoors. I have a remote TX/RX pair that has a relay built into the receiver that could do this. Something like £5 from the Chinese gang.
