Old 15th December 2017, 10:38 AM
OK so if you turn to HI and it comes out HOT at the other vents, the valves and pump must be OK, the heather matrix must be OK so must be flaps. You have tried the output tests, there is a flap position learning function somewhere in the VCDS, have you tried that? Could do with seeing a diagram on SSP or photos on google images of all the pipes, flaps and ducts.
