View Single Post
Old 27th December 2017, 08:17 PM
Thanks for the replies. The tank was completely empty on that first fill. It sits on its side.
I have a record of daily levels from the tank telemetry. It will vary with temperature, but only by a percentage point or two.
My inept understanding of Boyels law indicates that while it is definitely in liquid form when it leaves the tanker and is counted in fluid litres. When it enters the empty tank it will initially phase change to a gas, but once the tank reaches the prescribed pressure the gas will liquify and all further LPG will remain in liquid form.
While the space for propane in its gaseous state decreases, the pressure will remain constant while it phase changes to liquid as the space is reduced by the incoming liquid. The capicty is then measured by a float.
While the volume of the liquid may change due to temperature it won't be by much; ergo the 1 or 2 % differences.
But 5 (approx) liters per % point? It makes me wonder.....
