Originally Posted by paulrstaylor
Was it hot or cold at the time?
Just getting back to where Paul was heading with this - the 'Max' mark on the reservoir is the hot level. The 'Min' mark (just under the lip of the reservoir top) is the cold level. When cold, if it's at the lower mark it doesn't require filling.
Correct coolant is G12, which has been superceded by G12+ (or ++). All are compatible with each other.
Don't mix G13 (new standard) with G12.
