View Single Post
Old 2nd January 2018, 10:03 AM
johnny_quattro's Avatar
Default Small world?
I've already downloaded the VM via torrent and like a good chap, I'm now seeding. Left it seeding overnight and saw that traffic was destined for a Northern Ireland geo-IP address.
The only issue I had with the VMDK files getting them to run under VirtualBox - the key is to select probably the smallest .vmdk file named 'Windows 7 Odis-s016.vmdk' (that contains the embedded information to link to the other multiple larger .vmdk files). If you select the first one as I did, it will complain about version not supported.I previously had ElsaWin v4 running under XP so this version of v5.3 running under Windows 7 seems a worthwhile upgrade.
