It depends on the offset of the wheel in terms of exactly how close but if they are winter wheels then they sound pretty close, don't forget you're changing the whole wheel and tyre and the whole overall diameter isn't going to be hugely different - check it out on www.willtheyfit.com
Assuming the offset and wheel width is the same -
CURRENT NEW
Diameter 700.5mm 686.6mm
Circumference 2200.7mm 2157mm
Poke 62mm 62mm
Inset 154mm 154mm
Speedo error 0% 2.02%
Reading at 30mph 30mph 30.61mph
Reading at 60mph 60mph 61.21mph
Ride height gain 0mm -6.95mm
Arch gap loss 0mm -6.95mm
