Old 21st February 2018, 09:27 PM
There is an auxiliary (electric) coolant pump as well that moves coolant through the heater matrix. Same pump moves coolant for the "AUX" heater function with the ignition off.
The ACP famously has a motor that can get very noisy, the solution to which is to disconnect it! I have done that on both my S8s.
Remember the CTS has two sensors in it, one drives the display on the dash, the other gives information to the engine ECU, so what you see on the dash doesn't necessarily mean anything. VCDS I think can read both.
