Old 6th March 2018, 11:51 AM
I wouldn't mind a circuit that can deactivate PDC when I'm towing! It's really annoying to have to keep deactivating it when reversing the trailer (6x4 box trailers are difficult to place where you want them first time!).
The factory tow pack on the Volvo does this (and gives you separate indicator indications too (should test the bulb warning!).
I suspect the D2 factory trailer loom would have done this too, but as they're NLA and unobtainium, I'll never find out...
Actually, even a toggle switch would do - is there a wire I can interrupt near the dash?
The factory harness does indeed have a function for this. The 13-pin Euro socket has a switch in it which disables the car's own rear fog light (in favour of the one on the trailer) and turns off the PDC when a plug is inserted. Its a single wire in to the PDC module in the boot, I forget which pin. If you have a 7-pin socket I'm not sure how you would do it automatically.
