  #38
Old 8th March 2018, 12:40 PM
Though thinking about it, when I cut out the (partially pre-cut) panel to fit my ski hatch the material was pretty thin and as soft as toffee!
The felt material covering that behind-the seat panel in the boot is now back in place, but I don't recall noticing any serious structural/bracing clues on it's rather large flat surface.
To cut through the aluminium I used an oscillating tool similar to those used to cut plaster casts off limbs, it took literally moments to do.
The central seat belt on facelift D2s being a lap/diagonal type will obviously require significant strength in the upper mounting, presumably from a cross-member and/or the parcel shelf?
