As I have mentioned, I ran a scan after I got the car back which looked bad.
I'll attach a (pdf) screenshot of the engine faults, from my iPad.
After considering my options, I decided to erase the faults and have a look again after a drive.
A big thank you MJ for helping me to understand that all the errors had to be somewhat connected
Wow  Its interesting that most of the modules simply say 'electrical malfunction' rather than voltage too high or low. That might be a prefacelift thing though. ME7 in the facelifts is a little more verbose in its error messages.
I think the first things I would be looking at are the battery, alternator, and earth connections, particularly the earth strap from engine to body. Then probably monitor the battery voltage with a multimeter to see what its doing.
Some of those codes like the immobiliser and alarm are pretty normal. The open or short codes are likely caused by whatever is also triggering the electrical malfunction codes, in modules which aren't smart enough to detect a voltage issue.
I ran a full auto scan again today. And I am relieved to see that a lot of the reported faults didn't return.
Which brings me back to the Audi dealer. Why didn't they reset the faults when they serviced, and then made the repairs
Was VAG 1551 the only tool they had? Weird
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
