6th August 2010, 11:55 AM
Originally Posted by Mick
The RNS-D requires another 12v feed that isnt present on non sat nav cars.
If you look on the RNS there should be a wiring diagram showing which is the safe wire.
The SAFE displayed on the screen is not related to the lock code but without it connected you cannot enter the code.
Yup - i found that out after playing around with it in my old A4 which had a Symphony double din unit in it.
When i plug it into my S8 (equipped with a RNS-D and TV tuner) i still get safe. I am yet to try leaving it plugged in for an hour.
