Originally Posted by MikkiJayne
That's got me thinking now - it might be possible to fashion a contrivance which would replace the oil in the radiator before you put the top line back on, then you don't need to mess around underneath. Hmm...
That's exactly what I did when replacing my radiator
I put the bottom trans line on, then used a 20ml syringe (just because it was the size I had in the first aid kit) with a 6" piece of vac hose on the end to add some fresh ATF in the top hole until that was full and put the top line on. No worries!
you also need to get to VCDS to monitor the gearbox temperature so it can't be all the way up in the air (unless you have a USB extension maybe?). I tend to do it about 4" up in the air so I can still see the laptop
We just used an infrared gun type thermometer and monitored the trans sump temp.
We weren't too critical about the process though...
