  #48
Old 12th April 2018, 08:39 AM
That cracked weld is a bit worrying. I wonder if it's a common problem. Can the weld joint be seen/inspected without major disassembly?
Given that MJ believes the usual cause to be "potholing" then I wouldnt be surprised if its a common problem given the state of the roads. My Indy garage reckons that he sees a big increase in suspension/wheel damage over the past few years as the roads deteriorate.
