Old 12th April 2018, 08:54 AM
pete-p's Avatar
pete-p pete-p is offline
Given that MJ believes the usual cause to be "potholing" then I wouldnt be surprised if its a common problem given the state of the roads. My Indy garage reckons that he sees a big increase in suspension/wheel damage over the past few years as the roads deteriorate.
Originally Posted by MJ
... I believe this is from hitting a pothole and bottoming out...
If it is a case that the suspension bottomed out, would it not be more likely to happen if the car has been lowered or the suspension stiffened? Or if it was a particularly big hole!
Cars...
