Old 13th April 2018, 09:11 PM
A more successful day today, albeit still with considerable upside-down backwards spine bending!
This is where the clutch hose screws in to the master cylinder It took about an hour of wiggling and tweaking to get the union at just the right angle for it to catch the thread.
Here it is from the engine bay. I reattached the slave cylinder and pressure bled it while the engine was out.
I finished off the paint too. Completely forgot to get pics of it in primer, but basically I've feathered the edges of each paint stage to blend it in.
Some colour on
Then clearcoat / lacquer
Complete
I'm pleased with the work, but rather disappointed with the colour match. The aerosol ended up having rather more purple in it than the original paint which in comparison is more green. If it was the same colour the repair would be nearly invisible. As it is, its acceptable considering you can't see it without removing parts.
Engine ready to go back in
And bolted back in the car
Vera was able to stay long enough this evening to see the marriage of car and new engine
ID:	18428   Click image for larger version
ID:	18429   Click image for larger version
ID:	18430   Click image for larger version
ID:	18431   Click image for larger version
ID:	18432   Click image for larger version
ID:	18433   Click image for larger version
ID:	18434   Click image for larger version
