Old 15th April 2018, 09:33 PM
I'm using a vaccum tool to fill the coolant. Normally a V8 will fill easily but with the aux heater and LPG I want to avoid any chance of airlocks. This tool uses compressed air passing by a venturi to pull a vacuum on the cooling system. Once it's got a decent vacuum you can leave it for a while to make sure it holds (therefore checking for leaks) and then open a valve to suck in fresh coolant.
Partial vacuum held for about ten minutes
Much gurgling later, 10 litres of coolant sucked in
Moved on to the starter junction box
Cracked as usual
This is the last ever prefacelift junction box
Luckily I have plenty of facelift versions which are actually better as they are closed at one end so I will fit one of these instead
Filled with spray grease
Fixed
The centre silencer had a large crack where it joined the downpipe
The lovely team at A8parts sent us another one Cleaned the ends up so they would fit the Supersport backbox
Unconventional fitting (for an Audi) on the backbox. This was not fun to reassemble!
On the transmission jack ready to go back on
Had to squeeze the pipes together by 2mm to get it to go back together!
Engine complete and running
ID:	18460   Click image for larger version
ID:	18461   Click image for larger version
ID:	18462   Click image for larger version
ID:	18463   Click image for larger version
ID:	18464   Click image for larger version
ID:	18465   Click image for larger version
ID:	18466   Click image for larger version
ID:	18467   Click image for larger version
ID:	18468   Click image for larger version
ID:	18470   Click image for larger version
ID:	18471   Click image for larger version
ID:	18472   Click image for larger version
ID:	18473   Click image for larger version
