Originally Posted by IT
I believe they are press cars, hence so many identical ones. Despite the common myth, dealers rarely spec more than an option or two as at the end of the day they have to sell the car for list price, and its tougher to shift when they're loaded up high with spec (and cost)
OV and OU reg cars in particular are generally Audi UK registered, so were build for a 'show off' purpose of some kind no doubt....
You could well be right, there are a couple of clear batches on OV10 plates, silver seem to be higher spec than the black ones..... was there an Audi sponsored event in 2010 they needed a fleet for!?
Mine sat unregistered in a yard/showroom, was registered as a 60 plate and bought by the first owner with a very low mileage, also a few tweaks to the “usual” spec, still has a “launch” PR code on the build sticker!
There is a (smaller) batch of “launch” spec face lift cars also, but they tend to be 3l TDIs engine wise.....
I know that prior to the D5 launch there was a survey of D4 owners I took part in to assess which options should be standard, which included ACC
on the down side I think laminated side glass is now optional!?
