Thread: Wheel Spacers
View Single Post
Old 11th May 2018, 04:53 PM
Photos will follow tomorrow. The ones on the front, that I’m sure I bought as 10mm say 15mm on them.
As to bolt-to-hub versus bolt-through (with extended bolts), I’ve had 2 really bad experiences with the former.
The first was after having the discs skimmed in situ. To cut a long story short, the garage obviously removed the rear spacers to skim the discs and didn’t torque one of them up properly. But the wheel bolts were done up correctly. Result - the wheel came off on the M6!
Second, another garage over tightened the wheel to spacer bolts and stripped the thread (it’s only a shallow thread into aluminium). So I had to have the spacers replaced and, because the bolts that secure the spacer to the hub are recessed, theye were a real PITA to remove.
So, I’m now a bolt-through convert!
