Old 17th May 2018, 02:03 PM
All done, many thanks Adrian and great to see you again, though sad you don't have an S8.
Adrian is a dab hand at whipping out all the trim around the boot and it's certainly easier without that in the way.
Two people on the job, also helps; one leaning over the rear wing from outside taking the weight of the battery while the other manipulates the cables.
Minor problem: the vent tube wasn't connected to the old battery (no evidence of overflow thankfully) and can't be connected to the new one.
It's missing an adapter on the end that plugs into the vent hole on the battery.
Anyone know where they can be sourced, are they a standard VAG part or eBay item?
