View Single Post
Old 19th May 2018, 08:46 PM
Spanker's Avatar
Spanker Spanker is offline
I'd need to look, but there was a chap on ebay selling RNS-Es with the correct faceplate and a host of other options available to spec it how you want
For the small additional cost I would definitely get one of the later units with chrome power button - it doesn't then limit you to 4GB SD cards, which are a nightmare to get hold of now (most cheap 4GB SD cards are actually DSHC, just not marked as such, and don't work in the original RNS-E!)
You can also add an AMI interface (Notorious has one mounted in the cubby to the right of the steering column, which acts as a useful place to plug your phone in for charging/music) and I would definitely spec the bluetooth module for the OEM integration (doesn't do bluetooth streaming, unless the specs have changed with newer modules, which they might have)
I never found the lack of directions in the DIS bothered me that much, but maybe the member on here who has figured out CAN messages on the D3 instrument cluster could figure out why it doesn't work and knock up a suitable device to convert the signal?
I'm guessing you mean the RNS-E 2010?
Features of RNS-E
This device offered a wide range of navigation, convenience and entertainment features.
6.5-inch 16:9 ratio color LCD screen with 400x240 resolution
FM/AM radio
2 SD card slots for MP3 storage (up to 4GB each) located behind the LCD screen
DVD-based GPS navigation with traffic message channel support
Route guidance shown on DIS display
Multifunction steering wheel support
Controls and user interface very similar to Multi Media Interface
Rear view camera and parking sensors display (option)
Bluetooth handsfree system (option)
TV tuner (option)
Audio aux-in (option)
Satellite radio (option)
CD changer (option)
Audi Music Interface (option)
Firmware updates available through update CD or with maps DVD
User interface languages: English, German, Dutch, Italian, French, Spanish (other languages available with 3rd party updates)
Features of RNS-E 2010
Higher resolution LCD screen (800x480)
Support for SDHC memory cards
Chrome control knobs instead of plastic ones
MEDIA button instead of CD/TV or CD/SD
It would be a big shame if streaming couldn't be achieved as I am a Spotify man and currently enjoy BT streaming to my Dension. That's an option I'd have to explore.
I didn't know what an AMI was so Googled it and found this:
https://www.audi.co.uk/glossary/a/au...interface.html
I guess this is what you mean. It does suggest the possibility of wireless music playback so perhaps some hope there.
Dean
