Old 11th June 2018, 07:00 AM
Spanker's Avatar
Spanker Spanker is offline
I like the electric engine rig with memory function! I probably will keep the seat motors if no one has a use for them.
Dean - Lmk which bit it is and I'll stick your name on it, otherwise someone else might ask for it.
I am going to ask A8parts if they want the rest, but tbh its such low value I doubt its worth the storage space. See what they say tomorrow
It's the driver's seat side panel.
Mine is in very good condition with regards to the surface and marks etc., but at the bottom there is a crack from the base to the seat control section. When glued it will probably look OK.
But if you have one that's the same colour and is in a better condition then please can you keep that aside?
TIA
Dean
