Old 15th June 2018, 06:11 PM
Mine sometimes makes similar noise, usually if car has not been used for long time. My steering is normally in the upper most position and if it makes noise I can stop it by lowering steering column even just a little. I don't think it's UJ, it's more like like rubber squeaking rubbing on something. I suppose it could be dry bearing if it uses plastic/nylon bush type of bearing but not if it's ball/roller bearing. I would not spray WD40 on UJ, it will just wash out grease then evaporate and leave the joint dry. If there is a problem with UJ it will only solve the problem temporarily but if there is no problem it might create it.
