Old 13th August 2018, 07:18 PM
You can’t get all the ATF fluid out by draining it, so you’ll now have a mix. DIY fluid changes have caused problems for others and it’s usually recommended to have them flushed - but this requires specialist equipment. I’m not sure if there’s a ZF specialist near Leicester, but hopefully someone here will be along shortly with a more positive reply!
BTW, was it you at Belvoir Castle a few weeks ago?
