Old 9th October 2018, 08:43 AM
Unless someone knows the pinouts on the TV lead and the aux-in is actually separate from the TV sound?
A bit of searching and I found a couple of diagrams, summarised thus:
1. From AUX-in lead documentation; 21=AUX-NF-GND, 22=AUX-NF-In-Left, 6=AUX-NF-In-Right.
2. From RNS-E label?; AUX-NF as above, 13=NF-In-Right, 14=SHIELD-GND, 15=In-sync, 16=In-G, 28=NF-In-GND, 29=NF-In-Left, 30=RGBS-In-GND, 31=In-B, 32=In-R
So it would appear that the TV signals use different pins...….
Can anyone clarify what NF stands for?
It also seems that the TV signal, like the RNS-D input, is RGB not CVBS. So we have Red, Green, Blue, Sync, stereo sound and various Grounds.
This is why reversing cameras and aftermarket DVB-T boxes need extra interfaces; they almost invariable produce CVBS signals, occasionally HDMI as well, but never RGB.
The ultimate question will be, can the RNS-E be successfully configured to allow both AUX-IN and TV, they are coded separately so can be specified together?
