Old 25th October 2018, 07:56 PM
Default An interesting scan
Hi All,
I was asked to scan an A8 3.0 TDI for a reasonabvly local enthusiast.
Here is the resultant log. I have edited the owner details even though I have his permission to publish this.
Any comments?
Tuesday,23,October,2018,14:40:04:58733
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 18.2.1.2
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WAUZZZ4E46N0xxxxx License Plate: WV05xxx
Mileage: 242610km-150750mi Repair Order: #01
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 28 34 36 37 38
42 46 47 4F 52 53 55 56 57 61 62 72 76 77
VIN: WAUZZZ4E46N013222 Mileage: 242610km-150750miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 1010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 1010
36-Seat Mem. Drvr -- Status: Malfunction 1010
37-Navigation -- Status: Malfunction 1010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 1010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 1010
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C
Component: 3.0L V6TDI G000AG 0030
Revision: --H01--- Serial number: AUX3Z0E9375520
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 2959D191801C4F0C50-807C
8 Faults Found:
000260 - Mass Air Flow Sensor (G70)
P0104 - 001 - Intermittent - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 212488 km
Time Indication: 0
Date: 2018.02.22
Time: 00:03:26
Freeze Frame:
RPM: 273 /min
Torque: 234.0 Nm
Speed: 0.0 km/h
Duty Cycle: 80.9 %
Voltage: 10.03 V
Absolute Pres.: 999.6 mbar
Mass Air / Rev.: 0.0 mg/str
000258 - Mass Air Flow Sensor (G70)
P0102 - 001 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 212488 km
Time Indication: 0
Date: 2018.02.22
Time: 00:03:29
Freeze Frame:
RPM: 819 /min
Torque: 210.6 Nm
Speed: 0.0 km/h
Duty Cycle: 80.9 %
Voltage: 12.62 V
Absolute Pres.: 1009.8 mbar
Mass Air / Rev.: 487.6 mg/str
004195 - Fuel Pressure Regulation
P1063 - 004 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 212488 km
Time Indication: 0
Date: 2018.02.23
Time: 00:05:20
Freeze Frame:
RPM: 798 /min
Torque: 230.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Pressure: 184.6 bar
Duty Cycle: 51.3 %
005705 - Powertrain Data Bus
P1649 - 001 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2018.03.26
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
(no units): 24.0
Voltage: 11.02 V
(no units): 1.0
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 001 - Signal too High - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 4.980 V
Voltage: 10.49 V
Absolute Pres.: 979.2 mbar
Temperature: -90.0°C
000275 - Intake Air Temp. Sensor (G42)
P0113 - 001 - Signal too High - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 10.49 V
Temperature: 108.0°C
Temperature: 10.8°C
000566 - Manifold Pressure / Boost Sensor (G31)
P0236 - 001 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 4.980 V
Voltage: 5.70 V
001393 - Brake Switch (F)
P0571 - 001 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 14:02:47
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 10.72 V
(no units): 0.0
(no units): 0.0
Bin. Bits: 00000100
Readiness: 0 3 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E0 910 156 F HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0090
Revision: --H01--- Serial number: 4002839
Coding: 0000001
VCID: 2541DDA1EC046B6C74-8070
8 Faults Found:
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:49
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 4.0°C
T.B. Angle: 0.0°
18271 - Powertrain Data Bus
P1863 - 001 - Missing Message from Steering Angle Sensor - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:35
18290 - Powertrain Data Bus
P1882 - 001 - Missing Message from Electric Parking Brake Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:00
18289 - Powertrain Data Bus: Missing Message
P1881 - 001 - Acceleration Request - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:00
18275 - Powertrain Data Bus
P1867 - 001 - Missing Message from Steering Wheel (J527) - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:50
16944 - System Voltage
P0560 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 0 km
Time Indication: 0
18288 - Powertrain Data Bus
P1880 - 001 - Missing Message from Diagnostic Gateway - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:48
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 40
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:13:04
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008357
Shop #: WSC 00001 000 00000
VCID: 224BC6BDFD2A9C5411-8076
2 Faults Found:
18265 - Load Signal
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H07 0160
Revision: 01604707 Serial number: AUX3Z0E9375520
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58BFA455EBF606843F-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
7 Faults Found:
02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:18
02241 - Engine Control Module; Immobilizer Data not Adapted
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:18
02226 - Engine Control Module (ECM) 2; Immobilizer Data not Adapted
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:20
00192 - Rear Left Door Handle Touch Sensor (G417)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 76
Mileage: 0 km
Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:56
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 12
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:06
00166 - Access/Start Authorization Switch (E415)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 14
Reset counter: 116
Mileage: 212304 km
Time Indication: 0
Date: 2018.02.16
Time: 00:01:22
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3670112
Shop #: WSC 00000 785 00200
VCID: 2345C3B9E230955C1A-8076
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2017.10.22
Time: 13:50:28
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 0 km
Time Indication: 0
Date: 2005.01.01
Time: 00:00:00
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 Q HW: 4E0 035 729 A
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 300BJ057548940
Coding: 0000002
VCID: 2E53228DB9F2283485-807A
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 318BP057515187
Subsystem 3 - Serial number: 7401.02.0500000000218B0158˙
Subsystem 4 - Serial number: 8B0158˙
6 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:57
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:26:40
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:03
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:29
Freeze Frame:
Bin. Bits: 01
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:57
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 116
Time Indication: 15
Address 08: Auto HVAC Labels: User\4E0-910-043.lbl
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000062140
Coding: 1132625
VCID: 1C37F845DF4EAAA4DB-8048
13 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 209
Reset counter: 76
Mileage: 241771 km
Time Indication: 0
Date: 2017.09.20
Time: 10:16:18
Freeze Frame:
Voltage: 13.50 V
Temperature: 21.0°C
(no units): 192.0
(no units): 34.0
Temperature: 40.0°C
01592 - Air Quality Sensor (G238)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 18
Mileage: 241771 km
Time Indication: 0
Date: 2017.09.20
Time: 10:16:19
Freeze Frame:
Temperature: 22.0°C
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 115
Mileage: 241775 km
Time Indication: 0
Date: 2017.09.20
Time: 12:11:30
Freeze Frame:
Voltage: 13.40 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 140
Reset counter: 102
Mileage: 241828 km
Time Indication: 0
Date: 2017.09.21
Time: 09:34:28
Freeze Frame:
Voltage: 13.70 V
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 242599 km
Time Indication: 0
Date: 2017.10.20
Time: 20:45:31
Freeze Frame:
Temperature: 20.0°C
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:10
Freeze Frame:
Bin. Bits: 00011111
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:31
Freeze Frame:
Bin. Bits: 00011000
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:41
Freeze Frame:
Bin. Bits: 00011000
01853 - Heated Seat; Left Front (Z45)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Freeze Frame:
Temperature: 25.0°C
01854 - Heated Seat; Front Right (Z46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Freeze Frame:
Temperature: 25.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Freeze Frame:
Temperature: 25.0°C
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Freeze Frame:
Voltage: 11.30 V
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No HW: 4E0 907 279 L
Component: WWS NO RESPONSE
Coding: 0123001
VCID: 55A1AD61FCE43BEC24-8000
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
2 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.28
Time: 23:20:37
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 31
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63C583B9A2B0D55C5A-8036
8 Faults Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
01218 - Side Airbag Igniter; Passenger Side (N200)
01217 - Side Airbag Igniter; Driver Side (N199)
00591 - Seat Belt Switch; Driver (E24)
00592 - Seat Belt Switch; Passenger (E25)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: 65C19DA1AC84AB6CB4-8030
Component: Lenkradmodul H05 0080
5 Faults Found:
01426 - Controls in Steering Wheel (E221)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 66
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:23:55
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 23
Reset counter: 255
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:08:15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:53
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:27
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 F HW: 4E0 920 950 F
Component: KOMBIINSTR. VDO H53 0200
Revision: D05 Serial number: AUDID3E1000779
Coding: 0000413
Shop #: WSC 00011 067 57207
VCID: 275DD7A99608797C46-8072
2 Faults Found:
000 - -
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 51
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:51
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:19
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3BFE5DD57AD494C9-804E
5 Faults Found:
01406 - No Flame
000 - -
02251 - Heater Unit Locked
000 - -
33477 - Terminal Status
Unknown - 004 - - Intermittent
00456 - Control Module for Access and Start Control (J518)
000 - -
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 19003052170092
Coding: FCFE7FDE2B3504
14 Faults Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 30
Reset counter: 116
Mileage: 241790 km
Time Indication: 0
Date: 2017.09.20
Time: 12:41:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 116
Mileage: 241847 km
Time Indication: 0
Date: 2017.09.21
Time: 10:02:04
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01207 - Control Module for Auxiliary Heater (J364)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:08:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 116
Mileage: 0 km
Time Indication: 0
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 95
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:03
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBG8229001
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 83
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:08:12
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:50
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 92
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:08:12
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
7 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:18
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:18
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 76
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:06
Freeze Frame:
Fault Priority: 1
Fault Frequency: 14
Reset counter: 116
Mileage: 212304 km
Time Indication: 0
Date: 2018.02.16
Time: 00:01:22
Address 28: HVAC, Rear Labels: User\4E0-910-158.lbl
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0210
Revision: 00000017 Serial number: 00000000025011
Coding: 0000000
VCID: 61C989B1B8ACC74C48-8034
3 Faults Found:
01864 - Air Outlet Motor; Rear Right (V219)
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285FD4959B1676044F-807C
5 Faults Found:
01598 - Drive Battery Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 23
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 168
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:03
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 168
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:39
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:35
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 3670122
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2017.10.22
Time: 13:50:28
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 0 km
Time Indication: 0
Date: 2005.01.01
Time: 00:00:00
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 C
Component: MNS ECE H44 0850
Revision: 00000000 Serial number: 305BE057572015
VCID: 3B751BD97A80CD9C32-806E
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 13:52:15
02445 - Disk Drive Initialization Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:36
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000426700008
Coding: 0036004
VCID: 1D31F541C454A3AC2C-8048
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2004.03.25
Time: 00:02:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM002 0060
Coding: 0028590
VCID: 204FCCB5F3268E4407-8074
4 Faults Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 241952 km
Time Indication: 0
Date: 2017.09.23
Time: 10:04:02
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:06
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:10
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040503010096
Coding: 0004857
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
10 Faults Found:
00892 - Switch for Trunk Closing Cylinder (F248)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 186
Reset counter: 76
Mileage: 242226 km
Time Indication: 0
Date: 2017.10.03
Time: 09:12:58
01503 - Bulb for 3rd Brake Light (M25)
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 8
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:18
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 34
Reset counter: 116
Mileage: 0 km
Time Indication: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 187
Reset counter: 76
Time Indication: 1
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:34
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:35
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:05:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 15
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:04
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 80
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:06
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000011655
Coding: 0000013
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:50
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 13:49:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:32
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000056371
Coding: 0010101
VCID: 1E33F24DC952B8B435-804A
5 Faults Found:
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 12
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 262140 km
Time Indication: 0
Date: 2018.07.10
Time: 20:19:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 74
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2017.10.22
Time: 13:50:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
000 - -
Freeze Frame:
Fault Priority: 3
Reset counter: 76
Mileage: 242612 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM002 0060
Coding: 0028590
5 Faults Found:
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2017.10.22
Time: 14:14:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2017.10.22
Time: 14:15:46
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
Shop #: WSC 00468 210 91510
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Voltage: 10.97 V
Count: 247
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Voltage: 8.80 V
Count: 243
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Voltage: 8.28 V
Count: 41
02432 - Supply Voltage for Left Parking Brake Motor (V282)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 1
Fault Frequency: 5
Reset counter: 76
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:34
Freeze Frame:
Voltage: 12.01 V
Count: 86
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 76
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:56
Freeze Frame:
Voltage: 10.97 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000002
VCID: 62CB86BDBDAADC5451-8036
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242616 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:26
00070 - Starting Battery Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 8 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 242616 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:38
00255 - ABS Valves
015 - Cannot Be Tested at this Time - MIL ON
Freeze Frame:
Fault Status: 11101111
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 242616 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:41
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 242616 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:03
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 L HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0560
Revision: 00000000 Serial number: 396CV057505268
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 175
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:53
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 E HW: 4E0 919 146 C
Component: TV analog TUNER H14 0270
Revision: 00000022 Serial number: 00000000003528
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 13:53:06
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:19:04
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000006444
Shop #: WSC 00171 210 91005
Subsystem 1 - Part No: 4E0 915 105
Component: von TU3 7023479471
Coding: 344530393135313035202054553337303233343739343731
Shop #: WSC 12345 123 45725
5 Faults Found:
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:38:06
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 01:31:31
02255 - Voltage Measuring Lead from Vbat
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 10
Reset counter: 76
Time Indication: 0
Date: 2004.03.25
Time: 00:00:35
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:55
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:26
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0028590
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:14
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0028590
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:14
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720505401201
Coding: 0001008
VCID: 2149C9B1F82C874C08-8074
10 Faults Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 32
Mileage: 241933 km
Time Indication: 0
Date: 2017.09.22
Time: 15:42:43
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 20
Mileage: 241774 km
Time Indication: 0
Date: 2017.09.20
Time: 10:26:31
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 29
Mileage: 241774 km
Time Indication: 0
Date: 2017.09.20
Time: 10:26:31
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:02:20
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:05:48
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 18
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:00
01545 - Sensor for Parking Aid; Rear Left (G203)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 76
Mileage: 241774 km
Time Indication: 0
Date: 2017.09.20
Time: 10:26:30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:28
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 F HW: 4E0 862 335
Component: Handyvorb2 H10 0580
Revision: 00000000 Serial number: 00000007541090
Coding: 0010900
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 41
Time Indication: 15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 116
Time Indication: 15
End-------------------------(Elapsed Time: 03:43)--------------------------
