  #54
Old 3rd November 2018, 10:01 AM
Originally Posted by Green Goblin View Post
Is yours ticking at all? (I only ask as you said ticking over - was that a metaphor lol? Or just spinning quietly?)
It was indeed a metaphor but yes, sometimes, at lower light levels when barely moving you can hear a slight repetitive noise as if something is off-balance or there's some debris catching on the fan.
Given my other issues with seeds, debris, blocked scuttle drains, ill-fitting windscreen bottom trim etc. debris was my first suspect. Not least because fiddling with a wiring connector made a difference when it first happened.
But yes, if it does degenerate, replacing it is an obvious next step.
That said, it's not consistent and normally it's smooth and quiet, certainly when the ignition is on and it's getting full voltage.
Also the solar function is now disabled for the winter.
I think I documented that somewhere, but it's very easy to just tap into the return (earth) wire from the panel into the passenger footwell electrics panel.
I just looped that off to a convenient rocker switch, placed on the transmission tunnel side panel, and only visible/accessible with the glovebox open..
