Thread: Front breakpads
Old 3rd November 2018, 07:53 PM
I think 314mm brakes had dampers to reduce noise and 323mm did not as there was not enough space if fitting 16-17" winter wheels. They are interchangeable as long as you have enough space for dampers. If itiing the ones without dampers they may squeal a bit but like MJ says adhesive backing should eliminate that.
