Old 4th November 2018, 02:44 PM
lebesset lebesset is offline
I had issues with the passenger side on side just prior to the MOT. Tried the needle method, but it didn't help. What I ended up doing was removing the tubing from the jet, and then using a small syringe, forced hot water back down the jets, which cured the problem. I suspect that over the years, gunge somehow accumulates at the base of the jets, blocking them. By forcing water through them the wrong way seems to clear them.
thanks ...sounds exactly the same , will try that !
wonder why it is the passenger side , maybe the pressure is a little less !
just about to have my annual flu jab so the syringe should be just about the correct diameter needle !
