Old 20th December 2018, 04:54 PM
This is an interesting debate, but my thoughts (having taken the door apart for other reasons using Sean's guide) is where do you put anything?
It's all pretty tightly packed inside a D2, and the only "decent" sub I've seen described is MJ's which IIRC is in the boot and uses the ski hatch to emit sound into the cabin.
Plus if you take a door apart you WILL need at least some of the door card clips (they break) and I thought I read somewhere that they're NLA.
I've taken an "executive decision" having "upgraded" from a PF S8 with Bose to a non-Bose FL S8 to stick with OEM and enjoy the engine......
