24th December 2018, 11:39 AM
Hi Tiburon3, thank you so much for such a detailed post! Mine is also a facelift so will go for the latter instructions. Were there any particular issues with the fitting, trim removal or wiring? My plastics are also with the painters at the moment, will pick them up in the new year now probably.
The only Tech Dump I read was 30 - retrofitting the coolbox. I will have a look at the one you mentioned. Thank you
