  #42
Old 18th September 2010, 05:48 PM
GlynH GlynH is offline
I guess there cant be many D2's running RNS-E with working Audi TV Tuner too....
Well I must be one of the 'Lucky Few' then because I have had my RNS-E/TV Tuner in for over 2 years now...thanks CraigyB!
A question though for you guys with TV Tuner - although mine works 100% when I scan the car I always get the following error;
Address 57: TV Tuner Labels: None
Part No SW: 4D0 919 146 C HW: 4D0 919 146 C
Component: TV Tuner H02 0430
Revision: 01H02001 Serial number: 00000000003415
Coding: 0000030
Shop #: WSC 00000 000 00000
VCID: 295DB42DF992
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Not sure if this is normal or not because as I say it works perfectly but it would be nice to find out exactly what the coding should be as it does not seem to be listed in the VCDS labels...
Thanks & kind regards,
-=Glyn=-
