I like those wheels
Assuming you’re current tyres are 245/45/18 you have a few options but it depends on if you mind a bit of mild stretch.
Personally I’d think about going for a 255/40/19. I,ve got 255/35/20 on 9.5’s and there is a subtle stretch.
The calculator indicates your new wheels will sit 13mm closer to the struts....probably ok but worth checking you don’t need a spacer. MJ might know if there’s tonnes of clearance on these or not.
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor
