Old 4th February 2019, 08:13 PM
Default For sale - RS4 front brake conversion for D2 S8
Hi all,
I am able to offer a rare opportunity to acquire a set of B7 RS4 front brakes complete with brackets to make a bolt-on conversion for the facelift D2 S8. These are 8-pot calipers with 365mm semi-floating discs and despite being 20mm larger and considerably thicker, they're actually lighter than the original D2 345mm discs. They are also much more effective than the original D2 Brembos. Oh, sooo much more effective!
These are some pics of the conversion I just did on the manual swap:
Bear in mind these are factory drilled discs and so a bit noisier than solid discs. They're worth it though!
Price including brackets and hard-lines to suit the D2 is £1000. I can also supply braided hoses if needed, and obviously fit them if you fancy a trip to Devon.
The brakes are still on the donor car (which only has 53K miles on it) so I don't know about the state of the pads yet. They may well require replacing (£100-200) so please bear that in mind.
ID:	20804   Click image for larger version
ID:	20805   Click image for larger version
ID:	20806   Click image for larger version
ID:	20807   Click image for larger version
