Old 8th February 2019, 03:37 PM
Yes, low brake fluid will do the same. Will go and check that now
OK, Brake fluid is towards minimum but not low enough (I would have thought) to trigger the warning and, besides, but i wouldnt have thought that that would trigger a 01119 Gear recognition code. And, yes I have been reading the handbook
Low fluid would have been my guess too....
It might be above minimum, but if you set off in a rapid enough fashion, the fluid could slosh back and register low. I've definitely had this on a D2 S8 before.
I'd definitely top it up, as there's no harm in doing that, and it could help further diagnose that issue....
I concur that the low brake fluid warning is completely independent of the gear recognition code.....
