View Single Post
Old 10th February 2019, 01:48 PM
Well, the brake fluid level does seem to be the cause. Took it out today to pick up some brake fluid and going around a roundabout without acceleration it alarmed. Topped up the system and then took it out again - no alarms despite some hard acceleration/maneuvering
As the photo shows the level is not that low but I believe the sensor is at the front on the low level line so acceleration will cause an alarm.
Check scanned and cleared the DTCs so will take it out again after the rugby today and check what happens to the 01119 Gear Recognition signal....
Thanks for the suggestions guys.
