Old 12th February 2019, 08:12 PM
Default Slight Loss of Engine Oil
Late on Sunday I noticed a slight lowering of oil level on the dipstick. Bit worrying because she has never lost any between changes before.
No trace of oil spillage where I normally park.
I had to drive to Chepstow today so took her into my indie mate.
On the ramp we could see a little oil at the rear of the engine belly cover. Dropped cover and found oil around the sump plug. No oil visible higher than the bottom of the sump. Removed sump plug and the compression washer was compressed and of course was not reusable.
Made decision to put fresh oil in (he stocks it 'cos he has a TDI of his own for towing his Jet Ski) and ordered a new filter thinking that it would include a new sump plug washer; bugger no such luck.
Searched the garage and loads of new ones but nothing anywhere big enough.
1940's bodge it job, I had to get going. PTFE tape to the rescue. It worked the miracle.
Result! Had a goo, still good.d quick run down and only used quarter tank of the Devil's Tractor Fluid.
Checked oil level - still good.
