And yes for misfires swap coils and plugs around to see if fault follows them, failing that ignition amplifiers .
For the temp sensors- there are 2 one on each head, the one in the radiaor is just a simple thermo switch.
No need to clear faults. If the fault is not detected in next time it will run fine as without fault just store the fault in memory. If fault does not show up again in 30 or 40 times the ignition is turned it will be deleted itself.
