Old 13th March 2019, 07:24 AM
CrozA8's Avatar
CrozA8 CrozA8 is offline
These screws are difficult to see. (They are items Nš 7 in the diagram and fit through item Nš 8 into item Nš 14.)
I lean backwards into the open boot.
Then look upwards and into the grip.
Using a strong torch/light you will see the recessed screws. They might be covered with plastic pieces to hide them.
The crosspoint head of the screwdriver in the toolbox will fit them.
I find it more difficult to get the so & so's back in.
If you open the document that Neil suggested in a PDF viewer you might find that the actual page is "279"
OK TC4332, thanks for your direction. I knew there was something I was not seeing and it appears to be the camoed screw heads. I too did sit in the boot but could not see them.
Will attempt the same with a 1000 watt light source.
Thankyou for your assistance to both gentlemen above.
Chris
2006 A8 4.2 Ltr Silver Green 20" Factory Alloys
