Old 31st March 2019, 08:44 PM
I've had this on my D2. I think some people just rip off these panels, and then find out afterwards how they're attached.
The perpetrator of this mess actually stuck the broken part to the back of the panel with masking tape for someone else to fix later
Next job - find out why the ECU won't communicate with VCDS. No continuity between the body harness and ecu connector...
Well, there's your problem! I unwrapped the engine harness and this wire just broke when I touched it.
Look at the bulges in the insulation! This wire, somehow, has corroded from the inside out. These bulges are all along its length apart from an inch at either end, so the water hasn't got in from the ends. It's been absorbed through the PVC jacket, but only this wire! All the others are perfectly fine
Cut out the bad wire and spliced in a new piece
Comms re-established, I wrapped the harness up again and put it all back to bed
ID:	21049   Click image for larger version
ID:	21050   Click image for larger version
ID:	21051   Click image for larger version
ID:	21052   Click image for larger version
ID:	21054   Click image for larger version
ID:	21055   Click image for larger version
ID:	21056   Click image for larger version
ID:	21057   Click image for larger version
