View Single Post
Old 1st April 2019, 08:40 PM
4 hours of cleaning...
I pulled the oil cooler housing off. The plastic pipe had already cracked. That's getting replaced with an aluminium one.
Yeuch
I really don't know why these engines collect sand between the inlet manifold and the head. They all have it, and one has to be extremely careful when taking the manifold off to not get any down the inlet ports
Flange cleaned up and the inlet ports protected
There was evidence of coolant leakage down the back of the block so I pulled the water pipes off the back of the heads. Just as well I did since one o-ring had turned to fluff and the other was already leaking.
Cleaned up the valley
Breather cover removed - the gasket on this is the source of all the gunge in the valley and also all the oil down the back of the block. There's a little drain hole on the left of the pic where everything that leaks from here escapes down in to the bellhousing
More grub
2 gallons of degreaser later...
ID:	21078   Click image for larger version
ID:	21079   Click image for larger version
ID:	21080   Click image for larger version
ID:	21081   Click image for larger version
ID:	21082   Click image for larger version
ID:	21083   Click image for larger version
ID:	21084   Click image for larger version
ID:	21085   Click image for larger version
ID:	21086   Click image for larger version
ID:	21088   Click image for larger version
ID:	21089   Click image for larger version
ID:	21090   Click image for larger version
ID:	21091   Click image for larger version
ID:	21092   Click image for larger version
