Old 6th April 2019, 08:48 PM
Originally Posted by DailyMike View Post
Thanks, MikkiJayne!
I'll see if A8parts have one in stock first thing Monday! I need to order 04-off Lambda sensors from them too...I always get error codes relating to them. I mainly run the car on LPG..will the Lambda sensors being faulty effect the economy when running on LPG as well as on petrol?
Kind regards,
Mike.
I would go for new one as they are known to be common fault item. I think they brake down due to heat cycling an a second hand could fail soon again so could be false economy. Same for lambda sensors.
