Old 5th May 2019, 11:59 AM
Prefferle Prefferle is offline
Update; ok so I’ve disconnected battery and disconnected connectors to both ECU’s, all looked clean inside no signs of corrosion or water ingress. I sprayed these with Deoxit and reconnected.
Disconnected and checked all electrical harness connectors along with cleaning up all earth connections (coilpack earth on cyl heads and inside wheel-arches) that I could access.
Reconnected battery.
Start-up ok engine idles smooth with 0 misfire counts across all cylinders.
Test drive with VCDS still connected. No misfires detected.
So far so good. I’ll do a cold start and longer drive for the readiness tests to be completed.
Thanks again guys, I’ll keep updating.
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
