Old 2nd August 2019, 10:14 AM
johnny_quattro's Avatar
Default Orange drain plug - poor design
I've recently encountered the sloshing noise of water in the channels connecting the rear passengers vents on top of the propshaft tunnel. I did my usual trick to syphon the water with a suitable length of clear plastic tubing, which was both small and flexible enough to squeeze in between the vent fins... managed to extract/drain about a pint of water.
Moved on to the orange drain plugs either side of the transmission 'bulge' and discovered a pool of water on the front passenger seat footwell. I removed the weird orange drain plug that seems to be poorly designed (in my opinion) and cut about 3mm off the end with a sharp knife. See attached photos. Hopefully I won't ever suffer from this again.
ID:	22019   Click image for larger version
