Old 21st August 2019, 06:34 PM
There are two batteries marked as follows:
VARTA
2X3.6V 140 mAh
2x3/V150H Ni-MH
103 —>+
I'm struggling to find anything quite the same from any of my electronics suppliers. I'm sure that particular battery configuration used to be quite common but it looks like nobody stocks it any more.
I think I would probably just check the dimensions and make my own battery 'pack' instead, using something like this (assuming that has the correct dimensions). You'd need to tape (or, preferably, heatshrink) 2 of those together and solder wires to them instead. Don't solder directly to the battery though; some batteries have been known to explode when exposed to excessive heat from a soldering iron.
